I have three multidimensional rasters (temperature, wind gust max, wave height max) that I'm trying to run through a Weighted Overlay analysis using Raster Functions.
I have reclassed all three to a 1-3 Scale (aka using the Remap function I've gotten outputs where the pixels only have a value of 1, 2, or 3). When I feed those three remapped outputs into Weighted Overlay though, with a 1-3 Scale set, the Remap Table is blank.
I'm fairly new to this tool - I feel like it should be populating with values and scales, but it only says Value: NODATA, Scale: NODATA. Do I need to somehow manually fill in the Remap Table? Or should it populate on its own?
Could someone give me a little help on what I should expect for the Remap Table portion of this Raster Function? Or ideas on how to prep these rasters correctly/run this function correctly?
Much Appreciated! Screenshot for reference (only two rasters in this screenshot, but the problem is the same).
Got it up and running. I believe my issue was that even though I'd remapped to integer values, the input rasters were still reading in as doubles. Once I calculated the input rasters as integers, then the weighted overlay tool ran successfully.
Hi Heidi -
The behavior of raster functions is a bit different from how the GP tool behaves. I'm guessing thats whats causing the confusion in your scenario.
Here's a link which gives a detailed explanation of how the function works (with an explanation of the parameters)
Feel free to email me if you still run into issues.
