Dear Imagery and Remote Sensing
I went on through sample: Increase Image Resolution using | ArcGIS for Developers, in the notebook everything seems fine.
The problem came when I tried to classify Esri Imagery basemap via this tool. Tool ended with error: Input Raster does not support PIXEL_SPACE (raw image space). Running in MAP_SPACE. and the result image is black/empty.
Have anyone the same experience? Is there a way how to fix it?
Thank you for any idea.
Vladimir
Did you find a solution to this? I am having this same issue.
