Orthorectify One Image with GCP
1888
8
07-17-2017 02:05 PM
IsaacMedel_Calvo
Is possible Orthorectify one Image with GCP in ArcMap?. I don't found any example or help that explain how to do it. The only manner I saw is using images with RPC and MDT and use the Orthorectify function, but you can't use GCP.
If I use georeferencing as first step and create a new image I lost the RPC file and the Orthorectify button is disable.
I would like to do an orthorectification like others software did.
Thanks in Advance.
DanPatterson_Retired
Georeferencing a raster may be what you are looking for
IsaacMedel_Calvo
Hello Dan,
Thanks for your answer, but not exactly I looking for. I don't want a georeferencing imagen I need and Orthorectify image. The original image have a displacement, when I georeferencing the image appear in the correct place, if I create a new image, this image lost RPC and the Orthorectify function appear disable. If I update de georreference Image the image appear in the correct place but when apply the MDT with the update Image the result is the same as I don't use any GCP.
Thanks.
GünterDörffel
Occasional Contributor III
There is full Orthorectification in ArcGIS - have a look at the New Ortho-Workspace in Pro or the respective GP tools and the Frame Camera raster type ... but you will need more than just GCP's - you need inner and outer orientation of the frames.
IsaacMedel_Calvo
Hello Günter,
Thanks a lot for your answer, this is a RPC image and in I tried in ArcGIS Pro 2.0, and seems to works fine (I must do it more test). I would like a solution in ArcMap, because most of our cliente have ArcMap and the change to ArcGIS Pro is very difficult in a sort term. For new clients ArcGIS Pro is the best solution in this cases. If anyone know to do it in ArcMap could be great.
Thanks for your propousals.
GünterDörffel
Aaah - so it is RPC and not GCP  🙂
Is it from a commercial vendor that is in the list of supported raster types? Like GeoEye or DigitalGlobe? Then you should be able to add it to the Map or ingest it into a MosaicDataset. If it is not automatically recognized, you might see this and use the Image Analysis window and specify the location of the RPC information yourself ...
IsaacMedel_Calvo
Sorry, perhaps I don't explain correctly. I hava an Image con RPC (Geoeye 1, WV-3, Pleiades, and others), in many cases this images have some displacement, and you need 2 o 3 GCP to do a better Orthorectification using the MDT.
I review your links
Thanks a lot
GünterDörffel
Hi Isaac,
sorry - that beats me. I have never tried to follow a workflow that is intended for many scenes to just ONE Image. If you follow this workflow you MIGHT be succesful - given that you can specify a better DEM and import your GCP's ... but the effort is quite high. Would be interesting to hear if you find a solution or if this works. I have no sample imagery to test (especially no GCPs to go with it) ...
IsaacMedel_Calvo
Hi Günter,
I tried in ArcMap and works, but it's a little complicated and you have to do so many steps to have a good result.
I tried to do in ArcGIS Pro 2.0, the process is more easy, faster and the results are so good.
Thanks a lot
