Landsat image extent in decimal degrees
965
02-20-2017 10:51 PM
PoojaPandey1
New Contributor III
I do have some landsat datasets and I wish to process it with the srtm dem 30m. The spatial reference for both the files are same but both are showing two different extent, landsat showing in metres while the dem in decimal degrees. I've tried the data frame properties to change the landsat images in decimal degrees and also used the image analysis to change the extent but there's no difference in the extent. Help me with it.
JayantaPoddar
MVP Esteemed Contributor
