Ski lift maps are typically extremely distorted so as to focus on the primary areas of interest. If you are attempting to
georeference on against a base map you will need to add quite a lot of control points and I suggest you use the spline transform. You will likely need to add control point for each lift station some point along the lift, and points at locations along the runs and some on mountain tops, valley edges. Don't expect a pretty map.
