This is a newbie question. My DEM .img image looks good. When I load it into a mosaic dataset all I get is a solid grey image. What could be causing it? Is there something wrong with the image or something wrong in my mosaic dataset configuration?
Hi @EricS,
You may need to calculate statistics on the image. When adding the raster to the mosaic dataset, check the option Calculate Statistics under Raster Processing:
Yes statistics have been created but it still gives me the issue
alot can go wrong with MD display unfortunately. Definitely statistics was the first thing that came to mind. Not completely sure without seeing it. How big is it? would think the wireframe would be showing at the full extent. If it's a big data range and you've zoomed into a raster and still see a grey blob, it may be as simple as the area of elevation you're looking at having very similar values. In that case I'd adjust the symbology stretch to go by extent, and/or try a colour stretch rather than greyscale.
pixel type might be the issue, and there's the multitude of file types you can specify when adding a folder into the MD.
Just re-read the question. Is this multiple DEM.img's or just 1?
Were you ever able to figure out a solution for this? Loading DEMs into mosaic dataset results in gray boxes no matter what settings are applied.
