Hi all,
my first post here requesting for help with a Deep Learning Tool.
I run ArcGIS Pro 2.8.0 with the latest Python Packages and I am trying to run the Classify Objects using Deep Learning tool on a 8-bit unsigned 3-band TIF Raster file (Band 2,3,4) on a local drive.
I was relieved that my export training samples and train deep learning model went well without a hitch.
Export Training Data
Train Deep Learning Model
However, trying to run the Classify tool on my raster was not successful. The process would waver between 0-1%. I left it overnight for processing with the same situation where it would be stuck at 0%. Is there a reason why the tool is not running on my raster? Is it because of the background pixels in my raster?
Classify Objects using DL
Appreciate any comments or thoughts on my issue.
Thank you.
hey mate -@BrendanNewell , tagging you in here as well as you might be able to help 🙂
