a simple question on raster calculator
2398
11
10-16-2014 01:24 AM
giuseppeprocino
Dear all,
I have two raster with same area, extent and cell value:
- rasterA with only 0-1 value.
- rasterB with only 0-1,255 and null value.
I would obtain a third raster (rasterC) where if rasterA contain the value 1 and the rasterB contain the value 0 (for the same cell position) rasterC must contain the value 1. If the previous condition is false the value for the rasterC will be the same of rasterB.
How I can perform this condition within raster calculator in ArcGIS Desktop?
Giuseppe P.
DanPatterson_Retired
You want the Con statement in the spatial analyst.  You can build the syntax you want, but make sure that you pay attention case-sensitivity of the statements and the use of brackets.  here are examples
Con("grid1" < 2, 0, Con("grid1" < 3, 1, ("grid1" - 1) / 4.0))
Con(("polynom2" == 5)  & ("logistic" == 5), 1, 0)
in your case it might be
Con(("rasterA" == 1)  & ("rasterB" == 0), 1, 0)
but I haven't tested
giuseppeprocino
Hi Dan,
Con(("rasterA" == 1)  & ("rasterB" == 0), 1, 0).
I tried the following statement:Con(("rasterA" == 1)  & ("rasterB" == 0), 1, "rasterB").
but it doesn't work how I would like.
An example of my input raster (rasterA and rasterB) and the rasterC that I would obtain.
rasterA                    rasterB                             rasterC
010null11null11
10025502552550255
11100null11null
Giuseppe
I am surprised that the null values were even considered...on well
giuseppeprocino
The result is wrong with the statements:
or
show the results then as well as the input...I have nothing to test against, so I am going by instinct
giuseppeprocino
Hi Dan,
no problem but I'm still looking a solution .
FlorianHoedt1
I dont see an error here. You described:
which translates to this pseudocode (C#):
if ( rasterA == 1 && rasterB == 0)
     rasterC = 1;
else {
     rasterC = rasterB;
if rasterB is null it is not 0 therefore rasterC will be filled with rasterB value (null).
Which brings me to this question: What value do you want to get inserted in rasterC if rasterB has a null value?
giuseppeprocino
Hi Florian,
your pseudocode in C# is exactly what I want.
I want preserve null value.
FlorianHoedt1
