Change Color during Polyline editor
1911
02-28-2020 05:03 AM
CavronJeremy
Hello, I would like to know if it is possible in WPF C#, to change the color and thickness of the polyline editor during editing and not after validation?
For example, I want change polyline to Blue Color or another color. And change thickness. After I can continue Editing without outside Editing.
Thank you
RobertBorchert
Honored Contributor
Just create variable on what you want in symbols
If your doing this so you can keep track of an area you have worked with.
What I did one is I created an attribute and called it original shape length.  I then populated it with shape length
I then had the feature in two times using definition queries to make it visible if shape length = original and shape length <> to original.  In the second one it would change the color and thickness of the line.
CavronJeremy
Ok and thank you. I will try that.
RobertBorchert
Honored Contributor
I did it because an electric utility I worked with had a pole inventory done and purchased high end air photos.  They wanted to get off paper map books and go online.  Paper map books necessitated the lines being several hundred feet offset so they would not completely cover the road.
So I did this to easily keep track of where I had been in my mass move to move all the line to poles and ground devices.
CavronJeremy
Thank you.
By doing that, the "helper" changes during editing :
MyMapView.SketchEditor.Style.LineSymbol = new SimpleLineSymbol()
                    Color = YOUR_COLOR,
                    Style = SimpleLineSymbolStyle.Solid,
                    Width = 5
That working. thank you.
