How to configure Microsoft NLB to enable HA in ArcGIS Enterprise?
1512
09-03-2019 07:47 AM
by Anonymous User
Not applicable
Hi all,
I’m currently trying to install ArcGIS Enterprise 10.7.1 High Availability in my environment as follow :
* Inside
  •  2 servers for Portal for ArcGIS
  •  2 servers for ArcGIS Server
  • 2 servers for Data Store
& outside (DMZ)
  • 2 servers for web adaptors
I'm using Microsoft NLB as a load balancer for this environment.
I tried to configure the load balancer as described in the link below to enable HA but I don't know where to set the X-Forwarded-Host header and where to set the load balancer context name.
Configure a highly available portal—Portal for ArcGIS (10.7 and 10.7.1) | ArcGIS Enterprise
Thanks for your help.
Zakaria.
JonathanQuinn
Esri Notable Contributor
NLB by itself doesn't support custom headers. You'll need to use NLB along with the URL Rewrite module or ARR to add the necessary headers as well as implement health checking:
URL Rewrite Module 2.0 Configuration Reference | Microsoft Docs
Application Request Routing : The Official Microsoft IIS Site
by Anonymous User
Not applicable
Jonathan Quinn thanks for your answer. What about the load balancer context name? is it also set in the ARR or the URL Rewrite module?
Thanks.
Zakaria
