White lines/grid on cahce
1440
04-04-2018 06:39 AM
LindseyStone
I have 4 cache services, two street maps and two aerials, and today I'm noticing white lines on all 4 cache services that is laid out in a grid pattern.  I did just re-create tiles on my street cache and finished that yesterday.  However, I didn't notice the white lines when I checked service when I finished the first 5 scales a couple days ago.  In addition,  I haven't touched the two aerial cache in a few years.  So that shouldn't have been modified in anyway.  Here is a link to a live site that is running all 3 Land Use GIS Website .
I'm running ArcGIS Server 10.3.1 and Portal 10.3.1.
DerekLaw
Esri Esteemed Contributor
Hi Lindsey,
Are you using a mosaic dataset? Please see this Esri KnowledgeBase article,
Problem: Caching process creates blank/white tiles when using Mosaic dataset
Hope this helps,
TillStrauss
Hi @DerekLaw,
I found this old post, because a customer has the same issue. I think the Zoomlevel in the Browser is the problem:
Solved: Re: Some users see white lines around cached image... - Esri Community
Hope that helps
