Current environment:
I've completed a WebGIS DR restore to a new machine for our primary hosting server, and now when I try to federate the second server (Image Server) it is returning and error when it validates:
Error: The server at 'https://<FQDN of image server>:6443/arcgis/admin/info' returned and error. Server machine 'https://<FQDN of hosting server>:7443/arcgis/sharing/rest/community/self' returned an error. 'Invalid Token'.
Any ideas where to dig into this?
Hello @WarrenMedernach,
facing a similar issue when going through LB after webgisdr restore as well: did you ever find what was the issue ?
thanks !
Did you check the configuration of the LB it should allow the request if the internal machine name then traverse back with the hostname (webcontext URL) , is the SSL attached at the LB Level
Sorry to resurrect an old post, but did you ever get this to work? I'm experiencing the same issue.
Hi @NikoR , I'm really sorry, but I cannot recall exactly how we resolved this. It might have been a certificate issue, but I can't say for sure.
Check if your credentials align. I had similar issues after password changes and restores. parts of the deployments still had the old credentials and therefore could not generate the token.
Checking certificates is also a good tip.
