ArcGIS Server Service Description and Document Info edition
4139
10-29-2020 10:38 AM
jiyeam
Hello,
I'm curious to know how to edit the Service Description and Document Info section included in the ArcGIS Server.
More specifically, wherein the mxd file should I modify in order to see the different messages between "Service Description" and the "Comments" section included in the "Document Info".
2 Solutions
DerrickWong
Hi @jiyeam
You can edit it via ArcGIS Server Manager, ArcGIS Server Admin or ArcMap:
Hope that helps.
Regards,
Derrick
DerrickWong
Hi @KrisMilton1
It appears to be the case.
You can publish with SD via ArcGIS Server Manager:
If the service has been published to AGS and if you have access to the AGS file system, you can navigate to:
\arcgisserver\directories\arcgissystem\arcgisinput\XXX_SERVICE_NAME_XXX\extracted\v101 to retrieve your mxd.
Hope that helps.
Regards,
Derrick
DerrickWong
Hi @jiyeam
Hope that helps.
Regards,
Derrick
KrisMilton1
Hi Derrick!
From playing around, and from your response, it seems the only way to update the details in the 'Document Info' section are to go back and update the original ArcMap document.  Is that correct?  And any advice if you only have the .sd ?
DerrickWong
Hi @KrisMilton1
Hope that helps.
Regards,
Derrick
KrisMilton1
That's incredibly helpful - thank you @DerrickWong
I didn't know that trick for retrieving the mxd.
DerrickWong
@KrisMilton1
No worries. 😃
Could I kindly get you to kudos/accept as solution if you found my post helpful?
Thanks.
Derrick
