ArcGIS Server ETag header in single machine high-availability active-active configuration
981
05-23-2018 03:48 AM
NicolasGIS
Honored Contributor
In a single-machine-high-availability-active-active-deployment, though 2 webservices are exactly identical (same SDE geodatabase), but also identical:
- MapServer info json : https://x.y.z/arcgis/rest/services/Folder/Service/MapServer/?f=json
- Layer info json : https://x.y.z/arcgis/rest/services/Folder/Service/MapServer/layers?f=json
- Legend info json : https://x.y.z/arcgis/rest/services/Folder/Service/MapServer/legend?f=json
- Admin info json https://x.y.z/arcgis/admin/services/Folder/Service.MapServer?f=json
except the name of the host (extension["properties"]["appSchemaURI"], extension["properties"]["onlineResource"]),
I keep having 2 different ETag header for the same request preventing the user from using its cached answer.
Is there anything I overlooked or is that a limitation of a single-machine-high-availability scenario ?
Thanks !
