compare integer fields with code block
1013
02-18-2025 01:10 AM
itayroei
hallo community.
i try to compare 2 field with number and want to know in every row if tha numbers equal or not
can i get here simple code block  to get this result?
regards
itay
DanPatterson
you are missing the example and the code block you used
perhaps you could just create a simple integer field and use something like
def compare(a, b):
    """compare 2 fields and return 0 for different, 1 otherwise"""
    if a and b:
        val = 1 if a == b else 0
        return val
    return None
expression compare(!a!, !b!) where `a` and `b` are your field names enclosed in ! marks
... sort of retired...
itayroei
thank you Dan
it's really work 🙂
DanPatterson
good,
perhaps you could go back and click Accept as Solution on my response
