LoadLibrary failed with error 87: The parameter is incorrect.
1012
03-18-2020 05:47 PM
AndresCastillo
1 2 1,012
EDIT:
If the image is not loading properly, it says:
Error:
At my organization, we noted some ArcGIS Desktop users got this error when remoting into their workstations.
This error is due to the client machine's graphic card's driver being out of date, or conflicting with other
graphic cards in the machine.
This issue can be fixed by going to the graphic card manufacturers website and installing the latest driver.
Also, see the below documentation for possible resolution troubleshooting steps to take, which could required
elevated privileges to execute on client machines:
https://support.esri.com/en/technical-article/000020069
https://support.esri.com/en/technical-article/000013717
https://www.youtube.com/watch?v=S6u49E4IFcs
http://hongct.blogspot.com/2016/06/how-to-fix-loadlibrary-failed-with.html
Tags (1)
2 Comments
Asrujit_SenGupta
The image isn't loading...
And one suggestion: Instead of just adding a screenshot for error encountered, write it out as Text.
Text in an image cannot be searched while looking for solutions to any issue.
AndresCastillo
Thank you for letting me know Asrujit, and also for the suggestion.
This will be handy for me to know for future posts.
Fortunately for this post, the picture's text is the same as the title.
About the Author
I am really interested in Programming. GeoNet MVP.
