What is the Difference between Clip (Analysis) and Pairwise Clip (Analysis) GP Tools?
12449
03-27-2021 12:51 PM
tigerwoulds
Running ArcGIS Pro 2.7
Was getting ready to run a Clip on a set of polygons and came across the Pairwise Clip gp tool.
Clip (Analysis)—ArcGIS Pro | Documentation
Pairwise Clip (Analysis)—ArcGIS Pro | Documentation
What is the difference between the two and what is a use case to run one over the other? The documentation seems nearly identical.
JayantaPoddar
Pairwise Clip and Clip
Both tools use parallel processing. For the Pairwise Clip tool, parallel processing is enabled by default. For the Clip tool, it is enabled via the Parallel Processing Factor environment.
Please check the functional and performance considerations too. Comparison of classic overlay tools to pairwise overlay tools
Think Location
JayantaPoddar
Think Location
