Using Input names with iteration number
2809
7
06-24-2010 06:31 PM
HolmSeifert
Hi everybody,
i have a question about using input names in modelbuilder.
Does anyone knows a clue how to integrate input names in the output Class?
I have some input raster´s with different input names. Every raster is proccessed thorugh several tools. In the end I want for every output raster its input name plus the iteration index n.
Example:
Input raster: Test
--> several processes
Output raster: Test0
Thanks
KevinHibma
I'd have to see your model to be able to give you the exact syntax, but the basic idea is every "circle" part of ModelBuilder (the input/outputs) can be referenced via the name you set.
So, lets say you have copy features and it looks like this in the ModelBuilder window:
InputFeatures -- Copy Features -- OutputFeatures
If you are iterating over a bunch of FeatureClasses you already know about the "n".
So you can set the output to: %InputFeatures%_%n%
Which should give you something like:
roads -> roads_1
lakes -> lakes_2
rivers -> rivers_3
This help topic does a good job of explaining inline variables:
http://webhelp.esri.com/arcgisdesktop/9.3/body.cfm?tocVisable=1&ID=857&TopicName=In-line%20variable%...
HolmSeifert
Hallo Kevin,
thanks. For Featgures it works.
But I want to use this for Rasters. I have tried the sequence exactly like the copy sequence, but everytime this failure occur:
"A locator with this name does not exist."
I just create a simple process.
Copy Raster -- %Input Raster%_%n%
For the Input Raster i have choosen 2 Raster Datasets stored in a gdb.
Can you help me?
thanks
KevinHibma
Could you post your model or the picture of your model?
HolmSeifert
Hi Kevin,
here some data, a gdb, jpeg of the model and the failure message.
Hope you can find a solution.
thanks
Holm
HolmSeifert
here is the model
regards
Holm
KevinHibma
Holm,
Thanks for providing that - it clears up my understanding of the question.
The information I originally providing you with wont work in this situation. Unfortunately the LIST doesn't provide the %n%. Additionally you can't control the output name with the input name via the inline variable with a list in the manner I proposed. (my apologies, I'm confusing functionality between 931 and 10).
The %n% count is only available with SERIES and with the Iterators built into ArcGIS 10.
It may only be possible to accomplish this with a script. I'll have to look into it a little more.
HolmSeifert
Hi Kevin
thanks a lot. I guess now its time to learnin g python. 😉
At the momemt i´m learning it.
Next time i going to create a python script which allows to import different data.
I guess the command woulkd be something about the cursor command.
Hoppefully i will create the script till tomorrow.
(But there is fifa soccer :D)
thanks and regards
Holm
