Trouble with reclassify tool
5260
05-27-2011 05:01 PM
DanielBigelow
I am trying to create bands for a slope raster file in Arcmap 9.3,1. When I open up the reclassify tool, and click on the "classify" button to manually change the reclassification scheme, no new dialog box opens up. I also tried using the tool in ArcCatalog and the problem persists. Any ideas as to why this is happening?
BruceWiggins
I am observing the same behavior in v10.0.  But only for certain rasters.  For example, a DEM (unprojected) shows the dialog box for the "classify" button, but a projected version of the same DEM does not.  I can't tell why--any ideas would be appreciated!
curtvprice
I know this an old thread but reclassify only works on integer rasters. If you project a raster this could definitely create  float output.
The tool to "reclassify" float raster is the Slice tool.
AlexStum
Problem persist in 10.1
curtvprice
Have any of you tried rebuilding statistics on the slope raster first?
MahmoudMdookh
