tbx files at 10
1240
06-01-2010 09:27 AM
TedCronin
When installing 10, the tbx files are not being copied to their new location, so they have to be manually moved, is this expected?
ArcGIS 10.
KevinHibma
Ted,
I'm not sure what you're referring to. Can you provide some more information?
What toolboxes - system ones, custom ones...?
Are you performing a copy operation and it's failing?
TedCronin
The custom tbx (My Toolboxes) files that were part of a previous install, are not being copied to the new 10 install location.  sde files are copied, but tbx among a few are not copied to their respective location.
I can manually copy fine, its just I was expecting to open and see them in their correct location.  sde files have been correctly copied, I just thought tbx, odc, and ims files should be copied as well.
Does this make sense?
KevinHibma
I understand now - thanks.
Let me look into that.
TedCronin
Thank you Kevin.
