Spread Points out
3327
06-27-2012 07:51 PM
PatrickFischer1
Hi everyone,
I have a question about points. Sometimes you have a cluster of points on one area. In google earth when there is a cluster of points, you can mouse over it and it will spiderweb out into a series of lines where you can then select a point. Is there a way to make ArcMap(10.1) do this with points rather than manually drawing lines to the actual location of the points?
Thanks a bunch.
JonBodamer
Hi, you can use the Disperse Markers Tool with cartographic representations in ArcMap.
PatrickFischer1
While this works for normal points that you can use. Is there a way to also do something similar with Military Overlay Editor(MOLE) Graphics?
