Shapefiles within a Design Plan
1839
08-27-2014 06:05 AM
MarlaJohnson
When adding a shape file to a design plan it is not referenced correctly.  The work around is to pick it up and physically move it.  Is there a more accurate way to fix this?  It seems to always be an issue with GIS and micro station.
DanPatterson_Retired
GIS and shapefiles, use a projection file to give the file real world coordinates, does your microstation setup allow for the use of projections to define absolute coordinate space? or does it work in relative/arbitrary coordinate space?
MarlaJohnson
I do not think microstatin setup will allow you to do this. If it does I'm not sure how to do it.
PaulLohr
Are you importing a shapefile into Microstation? Or adding a shapefile and DGN to ArcMap?
If you know the coordinate system of both the DGN file and the shapefile, it should be possible to overlay one on the other. A little bit of detail and I may be able to help.
Paul Lohr
Lohr Geospatial Services, Inc.
