Script tool validation - update Paramaters arguments?
2470
05-07-2020 03:20 PM
AllenScully
creating some validation in a custom GP tool, getting an error in the tool after editing the validation code:
in TypeError: updateParameters() takes exactly 2 arguments (1 given)
But, here's the code:
def updateParameters(self,parameters):
"""Modify the values and properties of parameters before internal
validation is performed. This method is called whenever a parameter
has been changed."""
   if parameters[3].value:
      if parameters[3].value == "csv":
      parameters[4].enabled = False
      parameters[7].enabled = False
      parameters[8].enabled = False
   else:
      parameters[4].enabled = True
      parameters[7].enabled = True
      parameters[8].enabled = True
      parameters[9].enabled = False
      parameters[10].enabled = False
return
So, I see 2 arguments given, no?
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting
where is the part of the script that calls it?
 def is a method for the object
9. Classes — Python 3.8.3rc1 documentation
and it looks like you are passing a list to it, so I would expect
something.updateParameters(["a", "b", "csv", "d"])  # --- or something
where the parameter list has at least 11 entries
AllenScully
Thanks Dan -
I actually got it work simply by removing the 'parameters' from:
def updateParameters(self, parameters):
So -
def updateParameters(self):
got me rolling.  But it was all for naught, since validation code appears to be ignored when your script tool is published as a GP Service.
Allen
