Script tool dialog startup error "access is denied"
1559
09-10-2012 12:33 PM
curtvprice
Has anyone seen this error message when trying to start a Python script tool?
An error has occurred in the script on this page.
Access is denied.
file:///c:/Users/username/AppData/Roaming/ESRI/Desktop10.1/ArcToolbox/Dlg / MdDlgContent.htm
[ATTACH=CONFIG]17585[/ATTACH]
After you select OK the script tool opens and the tool executes fine.
curtvprice
The user that reported this issue could solve it by resetting their user profile. After doing this the error popup stopped appearing.
1. Close all ArcGIS desktop applications
2. Rename the folder "%APPDATA%\ESRI" to ESRI_old
curtvprice
MathewCoyle
Honored Contributor
Haven't seen it myself, came across this though.
http://forums.esri.com/Thread.asp?c=93&f=1148&t=173933
