Scaling a grid
1098
01-27-2020 07:27 AM
SLouq
by MVP Alum
I want to generate a grid scaled to one square mile per grid cell. Can I do this using the Grid Index Feature? What are the parameters to enter for width and height?
Scott
DavidPike
MVP Notable Contributor
Hi Scott,
It should work, the parameters I guess would be 1 mile wide and 1 mile high.
Create fishnet and generate tesselation should also do the job, with generate tesselation allowing you to specify an area.
Ensure you are in a projected coordinate system.
SLouq
by MVP Alum
Thanks for the reply David!
I figured out a way to generate what I wanted with the Grid Index Feature geoprocessing tool.
