Rectangle for Clip_management tool in arcpy
9270
11
08-02-2010 08:57 AM
RichNauman
Hello,
I have been struggling to get this part of a script to work. If I hard code the four coordinate pairs: like this:
rectangle = "-121.677618762735 42.7497214280392 -119.35205017646 45.3659860875993"
it works but we have to remember to change this every time we change study areas. When I run the script pasted below I get the following error:
  File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript
    exec codeObject in __main__.__dict__
  File "C:\Documents and Settings\Administrator\Desktop\clip_test.py", line 13, in <module>
    arcpy.Clip_management (raster, rectangle, outraster)
  File "C:\Program Files\ArcGIS\Desktop10.0\arcpy\arcpy\management.py", line 7692, in Clip
    raise e
ExecuteError: Failed to execute. Parameters are not valid.
ERROR 000840: The value is not a Envelope.
Failed to execute (Clip).
Here is my code:
import arcpy
arcpy.env.workspace = r"C:\Temp"
raster = "some_raster"
outraster = r"C:\output_raster"
extent = r"C:\GIS_Data\test_extent2.shp"
desc = arcpy.Describe(extent)
rectangle = desc.extent
print rectangle
# Clip_management (in_raster, rectangle, out_raster, {in_template_dataset}, {nodata_value}, {clipping_geometry})
print "Success!"
What am I missing?
Thanks!
ChrisSnyder
Honored Contributor
Try this:
import arcpy
extentFC = r"C:\GIS_Data\test_extent2.shp"
dsc = arcpy.describe(extent)
arcpy.Clip_management (raster, dsc.extent, outraster)
###or if you want to mask it using extentFC as the outline:
##arcpy.Clip_management (raster, dsc.extent, outraster, extentFC, "", "CLIPPINGGEOMETRY")
RichNauman
Thanks but I still get the "The value is not a Envelope." error:
  File "C:\Documents and Settings\Administrator\Desktop\clip_test.py", line 15, in <module>
    raise e
ChrisSnyder
Honored Contributor
Hmm... Maybe a bug in v10?
Here's an excerpt of some v9.3 code that works for me:
#Process: Creates a blank GDB
fgdbName = "oesf_score_gnn_raster"
fgdbPath = root + "\\" + fgdbName + ".gdb"
gp.CreateFileGDB_management(root, fgdbName); showGpMessage()
#Process: Extract the OESF
hcpUnitFC = r"\\Snarf\am\div_lm\ds\gis\tools\sde_connections_read\ropa_gis_layer_user.sde\ROPA.HCPUNIT"
oesfFC = fgdbPath + "\\oesf"
gp.Select_analysis(hcpUnitFC, oesfFC, "HCPUNIT_NM = 'OESF'"); showGpMessage()
#Process: Buffer the oesf
oesfBufferUnits = "FEET"
oesfBufferDistance = "35000" #NOTE: This MUST be the same buffer distance as in 'nso_make_path_distance_grids_v93.py'
oesfBufferFC = fgdbPath + "\\oesf_buff_" + str(oesfBufferDistance) + oesfBufferUnits.lower()
gp.Buffer_analysis(oesfFC, oesfBufferFC, str(oesfBufferDistance) + " " + oesfBufferUnits.upper(), "FULL", "ROUND", "NONE", ""); showGpMessage()
#Process: Clip the GNN data to our area of interest
gnnReadGrd = r"\\snarf\am\div_lm\ds\gis\tools\sde_connections_read\raster_gis_layer_user.sde\SHARED_LM.GNN_20100303"
gp.extent = oesfBufferFC
gp.extent = snapExtentToRaster(gp.extent, gnnReadGrd)
gp.mask = oesfBufferFC
gp.cellsize = gnnReadGrd
gnnClipGrd = fgdbPath + "\\gnn_clip"
gp.Clip_management(gnnReadGrd, gp.extent, gnnClipGrd, oesfBufferFC, "", "CLIPPINGGEOMETRY")
DavidWynne
Hi Richard,
You won't be able to use a Extent object directly as input to Clip, but since you can use geometry objects, Polygon, etc.  So, really it just a matter of converting that extent into a polygon.
Working from your original code, something like below should do it.
import arcpy
desc = arcpy.Describe(r"C:\GIS_Data\test_extent2.shp")
extent = desc.extent
rectangle = arcpy.Polygon(arcpy.Array([extent.lowerLeft, extent.upperLeft, extent.upperRight, extent.lowerRight, extent.lowerLeft]),
                          desc.spatialReference)
print rectangle
arcpy.Clip_management(raster, rectangle, outraster)
print "Success!"
-Dave
ChrisSnyder
Honored Contributor
Looks like I will be rewriting a lot of v9.3 code to make it arcpy compatible...
DavidWynne
Sorry, I was overthinking that example way too much.  It could also be done by converting the extent to a string like so:
arcpy.Clip_management(raster, str(extent), outraster)
Hopefully, that is more agreeable
-Dave
ChrisSnyder
Honored Contributor
I like that better!
RichNauman
Thanks for the help but I am still struggling.
This script works:
import arcpy
raster = r"Y:\GIS_Data\raster1"
outraster = r"Y:\GIS_Data\delete_me"
desc = arcpy.Describe(r"Y:\GIS_Data\test_extent2.shp")
frame = str(desc.extent)
frame = str(frame [:-16])
frame = str('"' + frame + '"')
print frame
arcpy.Clip_management (raster, "-121.677618762735 42.7497214280392 -119.35205017646 45.3659860875993", outraster)
print "Done!"
But this one does not:
import arcpy
print frame
arcpy.Clip_management (raster,frame, outraster)
print "Done!"
I copied and posted the output from the "print frame" statement into the clip statement to get it to work.
Any ideas?
DavidWynne
Don't bother with the extra quotes in this last line, I'm pretty sure this is the cause of your error.
Instead, just do this (leaving out your last frame = line)...
frame = frame[:-16]
or, if your intention is to strip out all the NaN's at the end, you could also do this...
frame = str(desc.extent).strip(" NaN")
