Raster ExtractByMask with python
3958
13
06-29-2010 02:39 AM
bogdanpalade1
I am trying to clip a raster with a polygon shapefile.The shapefile contains several polygons representing administrative regions. The method is to temporarily export each polygon to a new shapefile and to extract the coresponding piece of raster.
The problem is that the output of
gp.ExtractByMask_sa(raster, shapefile, newRaster)
is always just one band of the original RGB raster. Do you know how to extract all the 3 bands?
The original raster is .img
Thank you
ChrisSnyder
Honored Contributor
Try naming your shapefile something else than a number (1.shp). Generally it is a bad idea to name a layer or field with a number as the 1st character.
bogdanpalade1
Tried changing the shapefile name but still the same error....
ChrisSnyder
Honored Contributor
Not sure what's wrong... Take look at the sample code: http://forums.arcgis.com/threads/9512-Rectangle-for-Clip_management-tool-in-arcpy (my post Aug 2nd @10:25).
Are you sure that your raster and shapefile are using the same projection?
JamieWilliams
I had the same problem. I solved it by adding the full file path to the feature name.
eg. pathFeature = "R:\\folderContainingShpFile\\" + str(feature)
gp.clip_management(raster,"446716,298473 4425996,437405 499153,348855 4492682,68626",outRaster,pathFeature,"255","ClippingGeometry")
