Raster Clip Help
3450
03-20-2016 09:50 PM
BritneyVazquez
I'm having trouble clipping this raster layer to this polygon layer. The clip is successful, but the resulting polygon is only a portion of the original polygon. I was able to successfully clip to other layers from the same feature class as this polygon layer, so I am unsure why this particular polygon is not working. Any help would be greatly appreciated!
Tags (1)
NeilAyres
Sorry, but what are you saying here?
Your polygon only partially overlays your raster.
NeilAyres
BritneyVazquez
Well that would explain it. Thank you for your help and sorry for wasting your time!
DanPatterson_Retired
Britney, could you close the thread and mark Neil's correct so there is some closure for people that may be in a similar situation
NeilAyres
"Vince's" ??
ooops... corrected
