Python Script in Model Builder - Successful, but reports failure!
985
02-17-2012 10:37 PM
MatthewBarlow
This is a repost from the Python forum:
I have a python script being initiated within model builder. It takes input and output parameters from modelbuilder and runs a series of raster analysis functions. It creates the layers, reports back to modelbuilder, says it completed successfully, but then finishes with the typical "Failed to execute" message. I have confirmed thelayers are created and contain expected results, but the model doesn't reflect success - ie, no drop shadows on the tool and outputs. These outputs need to hook into a following function, but it won't initiate because of the perceived failure...
I could post the code and such, but really I think this is something simple or a known issue that somebody must know about! Any ideas?
Thanks in advance,
Matthew
JasonScheirer
Esri Alum
Are any of the Python tools using AddError() to put messages in the message box? Once a Python tool calls AddError(), the geoprocessor assumes that script failed.
