Python has no attributes
1954
6
06-28-2010 05:11 PM
HolmSeifert
Hi everyone,
i have a question.
have anyone an idea how i can solve this problem, occuring when runnig a pythin script.
type 'exceptions.AttributeError'>: 'module' object has no attribute 'arcv'
Failed to execute (Script).
thanks
DanPatterson_Retired
showing the script would help
perhaps it is supposed to be argv as in sys.argv
HolmSeifert
Hallo Dan Patterson,
yes, This was the solution. Instead of using sys.arcv I haves choosen "GetParameterAsText" and now it works very well.
Thank you very much for your help
Regards
Holm
it is argv not arcv
in any event, sys.argv and GetParameterAsText are equivalent if you need string representations of the input, sys.argv allows for the passing of numbers
DaleHoneycutt
From my experience, GetParameterAsText() and GetParameter() are preferable to sys.argv[].  sys.argv[] has a character limit (I think it's 1024) while GetParameterAsText() doesn't have a limit.  I know that 1024 is a lot, but I have exceeded it on occasion for data buried in a deep folder hierarchy.  If you need the raw number (integer, double), use GetParameter().
(Prior to 9.0, I think, GetParameterAsText() wouldn't work when called from the OS prompt, so you had to use sys.argv[] unless you always ran as a script tool. This limitation was fixed at 9.0)
SharynHickey1
Hi
I think I have a similar problem. I am trying to run a script as a script tool in ArcCatalog, however when I do I get this error message:
<type 'exceptions.AttributeError'>: 'module' object has no attribute 'GetParamaterAsText'
Failed to execute (SlopeRoad).
Though I have directed the inputs to be GetParamaterAsText in the script, I have copied some of the script to show what I have done. Is there something I have not added when changing it to as script tool with 'GetParamaterAsText' as the script works when I hard code the inputs??
import arcpy, os, string, sys
#overwrite existing data if there
#check out the ArcGIS Spatial Analyst extension license
Service_Areas = arcpy.GetParamaterAsText(0)
DEM = arcpy.GetParamaterAsText(1)
Mask_NOW = arcpy.GetParamaterAsText(2)
OutDirectory = arcpy.GetParameterAsText(3)
arcpy.env.extent = Service_Areas
#cell size
arcpy.env.cellSize = DEM
#mask
arcpy.env.mask = Mask_NOW
GAslope = arcpy.sa.Slope(DEM, "PERCENT_RISE")
GAslope.save(OutDirectory + "\sloperaster.gdb\GAslope")
Thanks for any help! 🙂
