NetCDF time dimension problem
2330
11-04-2010 06:14 AM
samulineuvonen
I've been working to get some NetCDF data into ArcMap 10.0 and am having trouble in getting the time dimension right. I've used the tool 'Make NetCDF Feature Layer' in Multidimension Tools and otherwise everything is ok, but in stead of getting data for 12 steps with one hour interval, I get 12 steps with 3 second interval. And to make things even more weird: if I export the in-memory feature to a shape file, the time values are changed so that only date (no time) is given and it is same for all records.
Another weird thing is that when I tried the exact same procedure and same data on another machine with ArcMap 9.2 everything worked fine. But since I need to do this using ArcGIS 10, I would appreciate some clues as to what the heck is going on...
I can provide more details, if somebody thinks they might be able to help me.
Samuli N.
Helsinki/Finland
