Multiple location points found within the same buffer issue
1497
07-09-2017 05:55 AM
YannickLi
I created buffers of 1km around individual grocery store facilities (purple dot symbol). However, within some buffer zones, there are also market fairs and informal street vendors (represented by orange dots and green triangle symbols respectively). I cannot figure out how to manage this "conflicting issue" of having other facilities within the same buffer since the buffer rings are supposed to be for the grocery stores.
I wanted to solve the issue described above so that I can use each buffer to calculate the Euclidean and Manhattan distances from the residential area (represented by pale green color) polygon centroids to each of the 3 types of facilities using their coordinates and tabulating in excel.
Can anyone help me out?
