Multipart Geometry
3729
01-09-2015 02:06 PM
KS1
I have a polyline that appears to be one line (one feature in the attribute table) but when you click on it and move some of the vertex points around they are not connected.  Is there a data clean up tool that can merge these together so that the polyline is really only one polyline?
MelitaKennedy
Esri Notable Contributor
Have you tried the Multipart to Singlepart tool?
Melita
FilipKrál
Hi, you should be able to do create simple line features from multi-line features using the Dissolve tool. provided that the vertices are close enough (tweak cluster tolerance environment setting if necessary).
Select the object ID field to dissolve by and tick the dissolve lines box.
Regards, Filip.
