multi part polygon to polygon
1337
06-13-2011 08:03 AM
JeremyTibbetts1
I have a multi part polygon created from bathymetry data.
When I converted the raster to polygon, it created several small polygons (I have attached a sample of the polygon).
What I am looking to do its create one solid polygon from all of these parts, ei. no space in between the smaller polygons.
I was wondering if there is any way of doing this.
Jeremy
DuncanHornby
MVP Notable Contributor
Jeremy,
Probably the easiest way is to reclassify your source raster dataset to create one big raster dataset of one value then covert that into the polygon?
Duncan
ChrisSnyder
Honored Contributor
Disn't look at the polygon, but maybe the Union tool with the "No_GAPS" option?
DanLee
by Esri Regular Contributor
If you have ArcGIS 9 or 10 with ArcInfo licensing, try Aggregate Polygons tool with an aggregation distance = 600m.
To go with the raster approach, perhaps you can try the Expand tool, followed by the Shrink tool in Spatial Analyst.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z00000036000000.htm
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//009z0000003m000000.htm
The Expand tool grows the raster areas so that they become connected/aggregated; the Shrink tool reduces the over-grown areas (shrinking back without disconnecting the areas). You need to figure out the suitable cell sizes.
In the resulting polygons contain small holes, you can use Eliminate Polygon Part tool (ArcGIS 10, Arcinfo licensing) to get rid of small holes.
Hope the above helps.
