A few weeks ago I posted about using street light buffers. I feel that it would be more beneficial to use "classes" of lighting; that is, Class 1 is the best lit whereas Class 5 is the worst lit, with Classes 2, 3, and 4 in between. I built a model which I believe will be able to make the necessary shapefiles. Unfortunately, the model always fails at the Select tool. What is the best way to get this to work?
I have a diagram of what I mean with the "classes", plus an image of the model, below.
[ATTACH=CONFIG]16839[/ATTACH]
[ATTACH=CONFIG]16838[/ATTACH]
