Model Builder Iterator overwriting name error?????
9619
14
10-16-2015 09:35 AM
JustinMeyers
I set up a model to iterate rasters and do a spatial analyst math int geoprocess.  i did a subset of my entire raster collection just to make sure it would work.  I have three rasters in a FGDB.  My output only had two rasters?  so I reran and had a different output.  same results.  I renamed the input rasters, same result?  Essentially the iterate is grabbing the last raster and naming the output the same as the first rasters output?????  Why is this happening?  See circled red boxes for exactly what is happening
DarrenWiens2
Are you using an inline variable to name the outputs?
JustinMeyers
yes i am.  that is why i am lost/ confused why it is trying to name/ write something that already ran/ exists
DarrenWiens2
It may help if we can see your model setup.
JustinMeyers
KyleBalke__GISP
Darren is correct, you need to use inline variable substitution in the output name of your final raster.  The output name of your raster should look like the following:
C:\globeland30\rasters4_work2.gdb\%Name%
The %Name% part will use the name of each input raster to your iterator as the output file name.
Hope that make sense.
Kyle
JustinMeyers
yes, i have the model setup with that.  that is why I am confused why it is overwriting with a name that 1)it isnt and 2)that already ran
I am not sure if this is a bug?
ZacharyHart
Honored Contributor
FWIW, I think you should have the 'What FGDB do you want' as a precondition before the iteration proceeds.
JustinMeyers
Zachary,
any idea why this is happening?
ZacharyHart
Honored Contributor
I don't think file format has anything to do with this here.
I was able to get the model to work correctly. For what its worth, I changed they name of the variable to 'Output_FGDB'...I don't like using things with spaces or special characters (unlikely culprit). I made this a precondition, validated the model, saved, and then ran it through the catalog window. [I wish I used smaller rasters!].
Here is my model:
And here are the results:
