Model Builder Help!
1081
10-24-2011 07:58 AM
MatthewVance
I created a model that runs just fine when I run it within model builder.  My problem arises when I try to execute the model from the toolbox.  All the processes run and there are no errors returned, yet I receive no output.  Any suggestions?
ErikOlson
Try setting the output as parameters in your model. This has worked for me when I ran into a similar problem. Not sure why it works, just saw the suggestion in another thread.
KevinHibma
It works because tools need parameters (so your suggestion is correct). The output parameters get added to your display or are available in the Results window.
Give a read here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/A_quick_tour_of_creating_tools_with_Mo...
If you checked "add to display" - this is a setting only used when running the model within the ModelBuilder window itself.
Further explained here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Displaying_model_data/002w0000003q0000...
