MapDocument
759
11-19-2009 07:43 AM
TedCronin
http://help.esri.com/en/arcgisdesktop/9.4/help/index.htm#/MapDocument/000V000000S9000000/
So, for the Map Document, is it CURRENT, or can Current be used when setting the MapDoc parameter.  The help is pretty clear that its CURRENT, but I can type 'Current', so perhaps its in caps to hightlight the value, thoughts...
JasonScheirer
Esri Alum
It's case insensitive. Convention here uses all-caps "CURRENT".
TedCronin
Thats how I've been doing it so far.
