joining polylines
3476
13
03-31-2013 12:26 PM
MalgorzataMendela
could you please help me to join two features (geometry type: polyline), knowing that these datasets do no have common parts (they are disjoint)? Which ArcGIS tool would be appropriate to solve this problem?
Thank you for your advice.
Best wishes,
Malgosia
MalgorzataMendela
Ok, I will try to test it. Thank you for your advice.
MalgorzataMendela
Unfortunately, the solution proposed at http://forums.arcgis.com/threads/894...t-to-multipart is not good, because Dissolve tool (Data management tools-Generalization) do not allow to create a singlepart from 2 separate feature classes-it is not possible to define as input data 2 feature classes, but only one.
MarkBoucher
Honored Contributor
Are you trying to relate the two or are you trying to correct the red line so it follows where the green line is? (refering to the desirable_result.zip�?? file you posted earlier)
MalgorzataMendela
I am trying to correct the red line so it follows where the green line is.
