Ignore errors instead of stopping in modelbuilder
9888
12
03-04-2013 06:10 AM
TomMagdaleno
I have a model which will pull 30 features from a database and a second model which will perform a feature class rename on these 30 different features.  This is done on a daily basis.  Sometimes one of the names will change or a feature won't be pulled in for some reason.
  The problem is that when the rename model is running if it can't find a feature it will error the entire model instead of ignoring the error and skipping to the next feature to rename.  None of the processes have preconditions.
Is their a way I can tell the model to ignore errors and move on if it can't find a feature?  A green error instead of a red one?
curtvprice
The only way I can think to do this is to use the Calculate Value tool to do the rename and have it return a message.  Calculate Value will print out the function results to geoprocessing messages as the model runs.
Of course this involves writing a small Python script:
I'm assuming you have two model elements "From FC" and "To FC" with the names.
Expression: FCRename(r"%From FC%",r"%To FC%")
def FCRename(from,to):
  import arcpy
  try:
    arcpy.Rename_management(from,to)
    return "rename %s to %s success!" % (from,to)
  except:
    return "rename %s to %s failed" % (from,to)
(note, you can pass as many arguments to the function as you want, or put the dictionary and for loop inside the Calculate Value if you want.)
curtvprice
  import arcpy
  try:
  except:
Note, you can pass as many arguments as you want. The "r" preceding the strings is important to make sure full path backslashes get interpreted right.
TomMagdaleno
Interesting...What error message were you getting?  I made a replica of your geodatabase in the exact same location  on my G: drive and executed the same code I posted above and it worked perfectly (Maybe I had your path name wrong?).  I have attached screenshots of the whole process below.
[ATTACH=CONFIG]22400[/ATTACH][ATTACH=CONFIG]22401[/ATTACH][ATTACH=CONFIG]22402[/ATTACH][ATTACH=CONFIG]22403[/ATTACH]
I got it.  Thank you Caleb.  User error on starting the python script, but it works now.
