I can't read shape points in py script, getPart() doesn't work
3215
8
05-24-2011 03:47 AM
EliaszHaas
Hi!
I've got layer of polygons and I'm trying to read with py script all shapes.
But for almost all shapes I can't read their geometries (getPart() returns nothing - I've checked partCount returns 0, but pointCount nonzero values)
Of course all objects are displayed well in ArcEditor
I use code similar to:
import arcpy
# Identify the geometry field
desc = arcpy.Describe("myLayer")
shapefieldname = desc.ShapeFieldName
# Create search cursor
rows = arcpy.SearchCursor(infc)
# Enter for loop for each feature/row
for row in rows:
    # Create the geometry object 'feat'
    feat = row.getValue(shapefieldname)
    pnt = feat.getPart()
    # Print x,y coordinates of current point
    print pnt.X, pnt.Y
What is going on?
Any idea?
Piotr
DanPatterson_Retired
The following function requires a shape from your search cursor, the type of shape (ie multipoint, polygon or polyline and the arcpy object.  You can glean the necessary lines for your code.
def shapeToPoints(a_shape,theType,arcpy):
  pnts = shapeToPoints(a_shape, shape type, geoprocessor)
  Purpose:  Converts a shape to points, the shape and its type
  are passed by the calling script
  Requires:  def pntXY(pnt)
  outList=[]
  part_num = 0
  part_count = a_shape.partCount
  if theType == "Multipoint":    #Multipoints
    while part_num < part_count:
      pnt = a_shape.getPart(part_num)
      XY = pntXY(pnt)
      if XY not in outList:
        outList.append(XY)
      part_num += 1
  else:                          #Poly* features
    while part_num < part_count: #cycle through the parts
      a_part = a_shape.getPart(part_num)
      pnt = a_part.next()
      while pnt:                 #cycle through the points
        XY = pntXY(pnt)
          outList.append(XY)
        pnt = a_part.next()
        if not pnt:              #null point check (rings/donuts)
          pnt = a_part.next()
          if pnt:
            XY = pntXY(pnt)
              outList.append(XY)
      part_num += 1
  return outList
EliaszHaas
Thanks
... but your code doesn't work the same way as mine. Me and you call getPart() function and it returs nothing (partCount returns 0 and pointCounts returns nonzero value). As I said my polygons are properly displayed in ArcScene, ArcEditor.
Piotr
ChrisSnyder
Honored Contributor
You need to provide an index to tell the .getpart() method what part you want to get. Get part is the way to deal with possible multipart shapes. If you are SURE your features are singlepart, then .getpart(0) will do the trick. Otherwise you need to loop through the parts as Dan's code is doing.
EliaszHaas
Hi
getPart() and getPart(0) return the same result: nothing - and that's my problem.
Piotr
ChrisSnyder
Honored Contributor
How about using .centroid? Here is a v93 example.
fc = r"D:\csny490\temp\road_pnts.shp"
pntDict = {}
dsc = gp.describe(fc)
shapeFieldName = dsc.shapefieldname
oidFieldName = dsc.oidfieldname
searchRows = gp.searchcursor(fc)
searchRow = searchRows.next()
while searchRow:
    shapeFieldValue = searchRow.getvalue(shapeFieldName)
    oidFieldValue = searchRow.getvalue(oidFieldName)
    centroidValue = shapeFieldValue.centroid
    xValue = centroidValue.x
    yValue = centroidValue.y
    if (xValue,yValue) in pntDict:
        pntDict[(xValue,yValue)].append(oidFieldValue]
    else:
        pntDict[(xValue,yValue)] = [oidFieldValue]
ChrisSnyder
Honored Contributor
pntDict = {}
while searchRow:
    else:
run the "repair geometry" tool on the file to check and correct any geometry errors
EliaszHaas
Thanks Dan!
I "repaired geometry" and it helped.
I did it for the first layer and I hope It'll work for other layers too.
That's my first task in ArcGis so I had no idea what to do 😉
Thanks
Piotr
