How to shift a raster
3795
02-15-2011 03:36 AM
TaiseerHarb
I have a raster (a rectangle). I want to shift it through giving the four corners new coordinates.
Could anyone help,
DanPatterson_Retired
shift....
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//00170000007t000000.htm
but why would you want to specify the four corners?
TaiseerHarb
actually the problem is more complicated than shifting a raster.
I am working with data sets from a climatological software (called COSMO) and imported these netcdf files into the ArcGIS. Now these files are based on a rotated coordination system, and not on a the real geographical system.
When I plot the country of interest - which should be in the middle of the domain I get its data as netcdf files from COSMO - the country is away from the domain. This is logic, because the country has the real geographical coordination system.
I wanted to shift the country to be in its (rotated) coordination system and to match the netcdf-based domain. This is correct but very inaccurate. Why? because all the x&y coordinates of the country should be transformed into the rotated coordination system. There is a FORTRAN script I wrote to transform these points. But the question now is:
*** How to get the whole x and y coordinate of a certain polygon, a country?
