How to not display NULL Values in a string label
11925
5
03-20-2017 09:16 AM
KevinWyckoff2
I have a feature class that I want to label based on three fields. It would be great if the first two fields always displayed, and the third only displayed when it isn't null. I have added all the field to a label no problem like this:
Is it possible to eliminate the word NULL in three of the five examples above?
JayantaPoddar
MVP Alum
You could use Using label classes to label features from the same layer differently—Help | ArcGIS for Desktop .
Create two classes and define SQL Query to identify the subset of the features you want to label in each class.
1. [Field3] IS NULL
2. [Field3] IS NOT NULL
Label Expression for Class 1
[Field1] + " " + [Field2]
Label Expression for Class 2
[Field1] + " " + [Field2] + " " + [Field3]
Think Location
JoshuaBixby
In addition to using label classes, you can define a FindLabel function (make sure to check 'Advanced'):
Expression:
def FindLabel( [Field1], [Field2], [Field3] ):
    return " ".join(str(field) for field in ( [Field1], [Field2], [Field3] ) if field)
Parser:
Python
NinaRihn
you could add this vb expression:
Function FindLabel ([field 1], [field 2], [field 3])
If [field 3] <> " " then
    FindLabel = [field 1] & " " & [field 2] & " " & [field 3]
else
end if
End Function
this works for me even with Null values
AbdullahAnter
Honored Contributor
If you have Null values in your field , it is automatically doesn't appear in label.
Just use simple expression: parser VBScript >
[Field1] & [Field2] &[Field3]
NinaRihn
that is true, however the vb expression comes in handy if you would like to add characters or spaces between each value, like this:
    FindLabel = [field 1] & "-" & [field 2] & "-" & [field 3]
else
end if
End Function
then the last dash doesn't show up if the last value is null
