how to measure cover types in buffer
3329
11-30-2011 09:57 AM
LilaniSamarakoon
I have land cover shp file which contains cropland, wetland, grassland, shrub and forest, etc.
In another layer I have established 100m buffer around wetlands. Then I need to measure the area of each of these cover types in the buffer area.
How can I do this ?
Tags (1)
DavidWilliams
Clip your land use polys with your buffer polys, then add a numeric attribute to your output layer and calculate their areas using the "Calculate Geometry" tool in ArcMap
ArcToolbox > Analysis Tools > Extract > Clip
