How to get the subtypefield?
849
08-30-2010 04:18 AM
deleted-user-tmoWMkOb1VrD
I try to make at tool that add some basic collums in front of a featureclass. then add some default values and dommains to the collums.
The problem is when the featureclass has subtypes. Then you have to add the deafault values and dommains pr. subtypevalue. And to make a list of all the subtype values you have to make a distinct of the subtypefield. But how do I get the Subtype field by using geoprocessing with python or vbs ?
KenHartling
I'm not sure if I fully understand your question, so to start, have you looked at the workflow for adding subtypes at http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Geoprocessing_workflow_for_subtypes/00... ?
If this doesn't answer your question, could you restate the question?
Ken
BruceHarold
Esri Frequent Contributor
Hi
The arcpy.Describe object also returns the subtypeFieldName.
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#//000v0000002s000000.htm
Regards
