How to get all relationshipclass properties using Python
1646
01-09-2013 04:09 AM
StevePeaslee
I need to get all the properties for a geodatabase relationshipclass. I can use a Python script to get most of the properties via the geoprocessing "Describe" but unless I'm missing something, the names of the primary and foreign key fields aren't exposed to this method.
Can someone please point me in the right direction? There has to be a way.
-Steve
brettangel
Did you ever find a solution to this?
JillianPenney
At 10.2.1 release, it will be possible to obtain the origin and destination class keys via python using the Describe function.
You can use:
arcpy.Describe(<relationshipclass>).OriginClassKeys  or
arcpy.Describe(<relationshipclass>).DestinationClassKeys
The result returned will look something like this:
[(u'OBJECTID', u'OriginPrimary', u''), (u'ParcelID', u'OriginForeign', u'')]
[(u'id', u'DestinationPrimary', u''), (u'RenterID', u'DestinationForeign', u'')]
Hope this helps!
StevePeaslee
Thanks Jill! Just have to be patient I guess.
-Steve
