geoprocessing service embed credential
922
04-12-2023 06:10 AM
JamesCrandall
MVP Alum
Enterprise 10.9.1 (build 28388) Federated to Portal
When publishing GP services to a federate Enterprise server site an item is created in portal and the share properties of that item dictate accessibility of that GP service.  For example, when making a request to the service's /execute task it requires a token parameter to be included.
This is fine and all but we want this GP service to be accessible with no authentication required, which if we set the share property to Public it works.  However, we don't want this to be a discoverable item in Portal!  This is mostly used by other systems and programmatic processes but we still don't want the item itself to be seen, just the url/endpoint should be accessed.
Any solutions?  Is there a way to set the share property to a restricted group but embed credentials into the item?
Thanks!
