Extract Data Task GP Service
5863
04-04-2016 02:26 AM
KrishV
Dear All,
Extract Data Task GP Service is working when Input mode is set to "Choice List" as per below screenshot. But this service is working only for layers shown in below screenshot.
I want to use this GP Service to work for any layer. Hence I have changed Input Mode to "User defined value" as shown in below screenshot but result is always failed.
Request you to suggest how to make this Extract Data Task GP service work for any layer.
Appreciate your support on this.
Regards,
Krish
JeffJacobson
You'll probably get better answers from the Geoprocessing section of GeoNet, as this doesn't have anything to do with the JavaScript API.
KrishV
Any advice on this is highly appreciated..! Thanks!
AndrewKeith3
You have to add all the layers you would to participate in this tool to the Table of Contents of your MXD as noted in the description.   This data would either need to be registered with the server you are publishing to or copied to server. This tool is out of the box, so you get what you get.
