Extract by Mask for each feature in a feature class
2443
06-18-2010 04:10 PM
RichNauman
Hello,
I am trying to create a python script to loop through each feature in a feature class and use each feature as the mask for an extract by mask.
Basically I have 12 polygons and want to calculate the mean value of a raster for each polygon - I could split the feature class into 12 feature classes each with one feature and loop through a list of the feature classes but that doesn't seem like the most elegant solution.
Any suggestions?
I tried a using a search cursor to loop through each row and use each row as the mask input value but get  an "Error in executing tool" error.
How do I covert the row object into an input for the tool?
Richard Nauman
Spatial Analysis Program Manager
National Center for Conservation Science and Policy
KimOllivier
Honored Contributor
Create an array object to receive the geometry from the row.
Then you can use that temporary feature as a mask polygon.
JeffLee
You need a search cursor and as you loop through the feature class table create a feature layer with each feature, then use the feature layer to clip your raster.  Here is a little bit of code that should help.
Wrows = gp.SearchCursor(WatershedPath)
Wrow = Wrows.next()
Nfeatures = gp.GetCount_management(WatershedPath)
gp.addmessage(str(Nfeatures) + " Records to Process")
count = 1
while Wrow:
[INDENT]      WFValue = str(Wrow.GetValue(WLayerF))
      gp.addmessage("Processing watershed " + str(WFValue))
      gp.MakeFeatureLayer_management(WatershedPath, "lyr", "OBJECTID="+str(Wrow.OBJECTID))
      gp.ExtractbyMask_sa(IFI, "lyr", OutFolder + "/" + WFValue)
      gp.delete("lyr")
      Wrow = Wrows.next()[/INDENT]
Watch for the indent as I just can't figure out how to post python code like in the old forum.  How the hell does one post code in this contraption?
StefanHaglund1
Hello,
Any suggestions?
Richard Nauman
Hi Richard,
If you want to calculate statistics of a raster you could use the Zonal Statistics tool in Spatial Analyst. It should give you what you want without needing to code.
Cheers,
Nooski
RichNauman
Thanks for the replies everyone.
Snoop pointed me in the direction I needed to go - The MakeFeatureLayer_management step with the where clause is what I didn't know how to do.
Richard Nauman
