Export Line Geometry?
4766
06-06-2017 09:23 AM
ZachSchenk
Hello All,
I'm trying to do some external analysis on a line that I have in ArcGIS. In order to do this, I need to export the line geometry so that I can see the line as a series of 'nodes'. Is there any way to find and export these nodes to a csv format? I know this is possible with QGIS so I expect its possible in ArcGIS as well... but I just can't seem to find it.
I also don't really need it in a csv, basically I need to run these points through a matlab script to calculate curvature ( I find that ArcGIS Curves and Lines tool isn't particularly useful for what I'm trying to do), so as long as these points are in a format that Matlab can read, I'm happy.
Any tips or help is appreciated!
Zach
BruceHarold
Esri Frequent Contributor
The Feature Vertices to Point geoprocessing tool (advanced license) might be what you need, followed by Add XY Coordinates then export the attribute table to TXT.
ZachSchenk
Any tips if I only happen to have a Standard License?
DanPatterson_Retired
you can use the free stuff provided by esri if you know a bit of python. FeatureclassToNumPyArray then save the coordinates out from numpy/python using savetxt.  Gives you a nice file which you can then use anywhere
JoshuaBixby
MVP Esteemed Contributor
Something like the following will create a list of named tuples for all of the points that make up the vertices for all of the lines in a polyline feature class:
>>> from collections import namedtuple
>>> line_fc = # path to line feature class
>>> point_record = namedtuple('point_record','line_oid x y')
>>> points = []
>>> with arcpy.da.SearchCursor(line_fc,["OID@","SHAPE@"]) as cur:
...     for oid, shape in cur:
...         points.extend([
...             point_record(oid, point.X, point.Y)
...             for part in shape.getPart()
...             for point in part
You can take the list of named tuples and either write it out to CSV or using an insert cursor to create a table or something else.
JoshuaBixby
I like Dan Patterson‌'s suggestion/approach more:
>>> points = arcpy.da.FeatureClassToNumPyArray(
...     line_fc,
...     ["OID@", "SHAPE@X", "SHAPE@Y"],
...     explode_to_points=True
